Major leak somewhere...Passenger floor soaked. help.
My friend has a 92 hatch.
he got into a accident hitting the passenger side corner first a while back
now he has this leak, that we cant figure out.
his passenger side floor gets soaked...it goes all the way back to the rear pass floor.
when they replaced the windshield, there seems to be a gap along the bottom from the rain gutter plastic thing...he taped it off thinking it was from that...but it still leaks.
its not fromt he doors, could it till be from behind the dash cuz of the windshield?
Re: Major leak somewhere...Passenger floor soaked. help. (Sucka Free SOLD)
How hard was the car hit? I would suggest looking at the heater core. Easy wasy to check is to get a pressure tester. And put it on the radiator. Turn your heater on and see if the floor board starts to get wet.
Re: Major leak somewhere...Passenger floor soaked. help. (Evil_Wizard)
check that the drain holes in the sides of your car arent clogged and the little plastic doo hickies that are under your hood near your windshield. my old g2 teggie leaked water on the driver and passenger side everytime it would rain cause of that
Re: Major leak somewhere...Passenger floor soaked. help. (MrJasey)
this seems like more the problem, but im guessing the water is running in from behind the dash down the firewall and into the floor board?
If not them things listed above....try checking the ac hoses/lines that goes thru the firewall on the passenger side. O rings might have to b replace.
Re: Major leak somewhere...Passenger floor soaked. help. (GAMEOVER 1.8)
Had the same problem couple of months back, but mine was on the driver's side. We stripped out the interior and did a full leak test, found out that water would dip in through the firewall.
D Tranny Guru
92-94.5 Civic TSB
The sealant around the hood hinge area is crap. Has been known to short out ECU's on occassion.
Re: Major leak somewhere...Passenger floor soaked. help. (Mista Bone)
92-94.5 Civic TSB
One word: chaulk!
D Tranny Guru
Re: Major leak somewhere...Passenger floor soaked. help. (98CTRCoupe)
Just what my Honda mechanic and fellow autoxer warned me about when I wrecked the front end and shifted the nose 4" in front of the shock tower.
No leaks yet!
No leaks yet!
mikecp
15
08-22-2010 07:56 AM
VSG
12-17-2008 04:35 AM
blu3g
10-07-2008 09:02 PM
