Lug Nut Issue
Old 04-02-2007, 04:48 PM
O RLY's Avatar
Default Lug Nut Issue
Well, this day has sucked. I was trying to remove my wheels to take off the rear hubs since I bought new ARP extended studs for all four wheels. The cheap *** lug nuts I bought a while back broke near the end, but we can't grip anything. One lug broke on each of the back wheels, so now I'm stuck and don't know what to do. We took out that 24mm nut on the back of the hub thinking the assembly might come off, but it didn't. What do I need to do to get the spindle off without removing the entire trailing arm?
Old 04-02-2007, 05:10 PM
Mistermark's Avatar
i had a similar problem but with the OEM studs, i ended up drill the old stud out and simple replace
Old 04-02-2007, 05:39 PM
O RLY's Avatar
Default Re: (Mistermark)
Well I got new ARP studs, so all I need is to get the assembly off. The shop I take them to can get the broken lug off each side. What do you need to take off in order to get to the spindle that hold the studs?
Old 04-03-2007, 11:44 AM
O RLY's Avatar
Default Re: (O RLY)
Bump. How can I remove the drum assembly without removing the trailing arm? I took off the 24mm nut on the back of the drum but it wouldn't come off. Any help would be great.
Old 04-03-2007, 12:12 PM
EL Vap133's Avatar
Default Re: (O RLY)
Old 04-03-2007, 12:33 PM
O RLY's Avatar
Default Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
So what bolts do I need to remove? I didn't need to remove the 24mm nut? Keep in mind I cannot just pull off the drum from the front, since I have a lugnut that is keeping the wheel on.
Old 04-04-2007, 04:53 PM
O RLY's Avatar
Default Re: (O RLY)
Bump. I'm going to go at this early tomorrow, so I'd like a game plan as to what to do. There are four star shaped bolts on the back of the drum assembly. Should I remove these, or will the 24mm nut allow me to remove the assembly. I need a way to get the stud out, whether I punch it out or cut it from the back, but I cannot get the wheel off the drum. Please help...
triumph_013
02-05-2013 11:25 AM
tallblondkid
06-05-2011 08:54 AM
eM2tK
Honda Civic (2001 - 2005)
03-09-2011 10:15 AM
reeder321
06-10-2006 01:01 PM
magic hat #9
08-07-2002 07:30 PM
Quick Reply: Lug Nut Issue
