lug nut threads
Old Jun 8, 2006 | 06:23 PM
reeder321's Avatar
Default lug nut threads
I recently bought and restored an old set of PRIME wheels and when i put them on the car with open ended acorn lugnuts they go on up to the second last thread. Will this be a problem or do I need to get some longer studs?
Old Jun 8, 2006 | 07:22 PM
reeder321's Avatar
Default Re: lug nut threads (reeder321)
bump
Old Jun 9, 2006 | 01:23 PM
old man neri's Avatar
Just as long as the entire nut fits on the stud you are fine. I would not recommend going through the massive hassle of extending your studs.
Oh and by the way there is no such thing as an open ended acorn nut. An acorn nut is a nut that has a closed rounded end.
Cheers!
Old Jun 9, 2006 | 04:58 PM
nsxtasy's Avatar
H-T Order of Merit
As long as you have at least six full turns on the lug nuts (seven is even better), you should be okay.
Old Jun 10, 2006 | 08:38 AM
reeder321's Avatar
Default Re: lug nut threads (old man neri)
well they go on all the way up to the last 1 or to threads of the open ended nut.
Old Jun 10, 2006 | 10:18 AM
reeder321's Avatar
i tried again today and I can get 6 1/2 turns on the stud. Are you positive this will be ok because if it is I'll save my money not getting longer studs. this is just for daily driving not for the track. thanx.
Old Jun 10, 2006 | 11:50 AM
nsxtasy's Avatar
H-T Order of Merit
Yes, that should be fine.
Old Jun 10, 2006 | 12:37 PM
wildoutwhitegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">Oh and by the way there is no such thing as an open ended acorn nut. An acorn nut is a nut that has a closed rounded end.
Cheers!</TD></TR></TABLE>
Are you sure?
http://www.ezaccessory.com/Ope...7.htm
Old Jun 10, 2006 | 01:01 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: lug nut threads (wildoutwhitegsr)
"Acorn" is one of the most confusing terms in the lug nut world, because it's used so many ways. Sometimes it refers to short lug nuts, whose length is about the same as their outer diameter. Sometimes it refers to the shape of the seating area (and that's even worse, because some people use "acorn" to refer to a tapered seating area, and others to refer to a spherical seating area). So there are lots of different interpretations to the word...
triumph_013
Feb 5, 2013 11:25 AM
eM2tK
Honda Civic (2001 - 2005)
Mar 9, 2011 10:15 AM
HCivExoo
Jan 18, 2009 06:36 AM
shooitzlinh
Mar 20, 2005 06:44 PM
VSMotorsports
May 12, 2004 12:44 PM
