LS/VTEC Turns over but won't start
I have a 95 civic ex with an LS/Vtec swap.
Eagle Rods and Pistons
pro 3 cams
skunk spring and retainers
wallbro fuel pump
6puk clutch
aluminum rad
b18 block
b16 head
was getting 11:1 compression, have not checked compression again.
it was up and running fine.
one day i was changing out the motor mounts and after i was done the car would not start. it cranks over and if i rev the gas the engine will stay on as long as i rev the gas.
if i do not rev the gas the car turns over and dies immediatly.
I changed the fuel filter and leaking fuel line figured that was the problem.
I changed the spark plugs and read out the the spark plug wires.
The spark plugs were not flooded with gas. and were gapped to .040.
B&M fuel pressure gauge reads 37 psi at the fuel filter which is stock fuel pressure.
i completely resoldered the main relay.
i do not think it is the ignition switch.
i sprayed out the map sensor with cleaner, but i have not read it out yet.
the IAC was discovered to be unplugged but plugging it in didnt help.
next i guess would be tps sensor or the computer itself or a whole new distributor.
at this point i think its an air problem maybe not enough fuel pressure im not sure.
i did notice an o2 sensor wire disconnected but i dont think thats it but i will replace it.
i am a long time lurker and first time poster of this forum, and yes i did use the search button.
pro 3 cams
wallbro fuel pump
6puk clutch
aluminum rad
b18 block
b16 head
Re: LS/VTEC Turns over but won't start
ill keep checking for grounds, i didnt see any blown fuses but i have to go through the fuses under the dash yet.
update........ i changed the idle air control valve. ignition coil and rotor where replaced. the distributor cap i had was corroded but i have to go get one that fits. i bought the wrong cap. i did try cleaning the cap however. installed new pcv valve.
i hate throwing parts at the problem but honestly i would have gone through and changed all this stuff anyways. with exception to the IACV. I did get it at a discounted price.
teg racer 877
04-07-2010 09:53 PM
Scotty_1988crxsi
11
02-17-2009 11:15 AM
