LS-V VS. "CTR" Plz help!
Well im kind of in a bind right now...
I am shoping around for a new motor for my car and i have come upon two choices.
Option 1:$2000
B16a2 Block
Pr32 Sir2 Head
S80 Itr LSD Tranny
Pro's: ITR LSD!chirping 1st,2nd,3rd gear :D B16 vtec, Sir high compression head, good power :D
Con's: Bad Piston rings, eats up the oil. Has at least 80,000 mi on it. No ECU and vtec wire installation.
(basically im on my own to add the vtec wires and ecu, Electrical mumbojumbo...)
Option 2:$1800
B18b Block
Gsr Head
GSR Tranny
Semi-Built
Pro's:
LS-V Power!
All electrical and ecu components taken care of :D
Guaranteed By mechanic to start and work
0mi on the block
New seals and gaskets
Semi built
only $1800
Con's:
How reliable can ls-vtec be?
Can i trust this mechanic
i need the car as a daily driver, is that possible with lsv?
Have heard that lsv needs extensive maintenance costs...
wats the probability i will have trouble down the road?
What road do you guys think i should take?
all commentary is appreciated
thanks JOS-EM1
Option 1:$2000
B16a2 Block
Pr32 Sir2 Head
S80 Itr LSD Tranny
Option 2:$1800
B18b Block
Gsr Head
GSR Tranny
Semi-Built
Pro's:
LS-V Power!
0mi on the block
Semi built
only $1800
Con's:
thanks JOS-EM1
Re: LS-V VS. "CTR" Plz help!
CTR in quotes because the motor hads CTR internals, pistons, cams, Intake... and the itr tranny
As far as the tuning of the lsv i have no knolege of how there tuning it.
Can you elaborate on what you mean on tuning?
ECU?
ECU?
LS-V is only as reliable as if it is built properly, so unless if you were to build it yourself cutting no corners i say stay away from it, otherwise boom!
Crazy Honda Guy
Let's see, different cams, different block, different rods, different pistons, different crank, different intake manifold, different throttle body....hmm, i see a pattern here
btw, a ctr is a B16B...different engine buddy
yes i know the ctr is a b16B
thats why i put ctr in quotes...
but thats not the point, im just trying to find out which engine to take
Forgot to mention this, My Budget is only $2300...
so basically i don't have room for much luxuries
The ECU controls the fuel and ignition maps responsible for safe operation of the engine. There is no stock computer that can run a LSVTEC properly.
When you put a LSVTEC together you are lowering the compression from a B16 or B18C and increasing the displacement, therefore the dynamics have changed radically.
A lot of people use a stock ECU or a "chipped" ECU with generic base map and this might run it but the AFR's aren't dead on. Extended use will deteriorate the engine, either by running rich washing ring lands and diluting engine oil or running lean causing cylinders to warp and/or the pistons to expand scoring the cylinders.
for 2300 i would go d series turbo!!!!!! and have money left over .btw I have a gsr wish I would have built the d and turbo and really be fast.
i'd go with the ls/v, then get the ecu tuned. with the other you'd have to have it rebuilt, which could run you another grand alone depending on what needs to be done to it. it never hurts to ask what all was done to the ls/v when it was being built, you know ask as many questions as possible.
If the LSV was built right (research the proper way...) then it could be fine. Just keep in mind that block was never designed to rev up to 8k like a GSR was. It totally depends how it was "built". Do you mean it has GSR water and oil pump, aftermarket rods and pistons, etc? Or what?
Also Kidnkorner, saying that building a LSV lowers compression is incorrect. The VTEC heads have smaller combustion chamber volumes. A LSV with a GSR head is slightly higher than a GSR.
the LSVTEC. also i heard that LSVTEC motors Timing will NEVER BE PERFECT unless u get adjustable cam gears. if built correct, they are just as reliable as any other motor. make sure theguy used the right parts or the motor will die lol. if the botom end gives out, LS motors are cheap and plentiful
tmekjian
04-21-2003 06:01 PM
