ls swap question
Old 05-19-2004, 05:06 AM
dsrconcepts's Avatar
Default ls swap question
If i was to put put a 91 ls in a 92-95 civic what would be involved the wiring. and would it be worth it? I only paid 500 dollars for the whole swap, and it came with aftermarket cam gears, header and intake, its got around 90,000 miles on it.
Modified by dsrconcepts at 6:16 AM 5/19/2004
Old 05-19-2004, 05:19 AM
jdm civic 2000's Avatar
Default Re: ls swap question (dsrconcepts)
edited his post about 92-95 being obd2
first off your 92-95 hatch back is a obd1 not obd2,that ls motor has a cable transmission? cause if it does that wont work because your car is hydro,so you would need to locate a b series hydro tranny for this engine....
Old 05-19-2004, 05:26 AM
Default Re: (Dimi)
90-93 use a cable transmission,94-01 use hydro on LS engine/models
Old 05-19-2004, 05:43 AM
Default Re: ls swap question (jdm civic 2000)
ya i realised this thats why edited it. and the engine does have 90k on it i have the car with it, i got it at an auction the car was trashed, broken rear window, water damage, ect.
Old 05-19-2004, 05:49 AM
so all i need is a cable transmission, well beside mounts, ect. can i use any b series cable tranny?
Old 05-19-2004, 05:56 AM
your car is 92-95 civic ,it uses a hydrolic transmission system,the engine you have is a 91 ls w/ a cable tranny,so you need to find a hydro b-series tranny,any bseries will work as lon as its a hydrolic type....mounts needed is a rear dohc del-sol mount,and shift lingage for any future q's
speedfreek128's Avatar
u can use a cable tranny....but u need to get a conversion kit/mount from hasport or some other company
Old 05-19-2004, 06:06 AM
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedfreek128 &raquo;</TD></TR><TR><TD CLASS="quote">u can use a cable tranny....but u need to get a conversion kit/mount from hasport or some other company</TD></TR></TABLE>
if thats the way he wants to go then thats his desicion,but imo they suck,and are tricky to assemble,if your a noob
Old 05-19-2004, 06:10 AM
since its a non-vtec engine u can use your current wire harness.....you will have to get a thermostat housing and fan switch from a 92+ B series though since the switch is by the oil pressure sender on 90-91
Old 05-19-2004, 08:14 AM
Question, the only mount i need is the rear dohc delsol and delsol shift link?
Old 05-19-2004, 08:28 AM
ok if i could get a list of parts needed or a good web site to go too then we can end this.
Old 05-19-2004, 08:49 AM
EG8 Dimitri's Avatar
Since the 1990-1993 Integras use cable transmission you won't be able to plug and play the motor and transmission. HasPort offers a kit to bolt into the 1992-1995 Honda Civic platform. The 1992-1995 Honda Civic platform utilizes a hydraulic transmission so a conversion kit can be bought through HasPort.
Here is the kit:
http://www.hasport.com/Product...C.htm
Here are the instructions:
http://www.hasport.com/Tech/In...l.htm
If you or someone you know can manage that install, go ahead.
In my opinion, go ahead and sell the cable transmission to the older 1993 or older Integra crowd and cough up a little bit more money and get yourself a 1994+ Integra transmission since those are hydraulic. Then, it'll be easier to install an no need for extra headaches.
Old 05-19-2004, 09:23 AM
CivicHatchback14's Avatar
a 91 LS motor is obd0 and the eg civic is obd1. I have heard you have to swich the distributor and the fuel injectors and stuff if you want to frun it in an obd1 car. also locating a hydro tranny will be much easier if you ask me.
Old 05-19-2004, 09:39 AM
MikeNice's Avatar
you need all 94 and up Integra manuel mounts. The only civic SOHC mount you can use is the one on top of the tranny. I would sell the cable tranny and look for a hydro tranny, and good luck with that cause its not easy to find a good one for cheap.
Old 05-19-2004, 10:45 AM
DaX
DaX's Avatar
I have the swap in my car.
I needed:
B-Series throttle cable
HA Sport Cable to Hydro tranny conversion
94+ Integra Rear mount bracket
Del Sol VTEC Driver mount and bracket
Del Sol VTEC AC bracket [for retaining AC]
OBD-1 P75 ECU
OBD-1 LS Distributor
94+ Integra Axles
You can use the 90-93 Shift linkage
94+ Integra injectors
You can use your civic wiring harness
94+ Integra thermostat housing
Old 05-19-2004, 11:05 AM
JDMH22HATCH's Avatar
Default Re: ls swap question (MikeNice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeNice &raquo;</TD></TR><TR><TD CLASS="quote">you need all 94 and up Integra manuel mounts. The only civic SOHC mount you can use is the one on top of the tranny.</TD></TR></TABLE>
This is not true. You can use the Civic rear mount if you want as long as you use the integra mount bracket.
Old 05-21-2004, 04:38 AM
well i sold the engine to a friend yesterday im saving up now for a b16
Old 05-21-2004, 04:56 AM
decent choice good luck when you get it
Old 05-21-2004, 06:51 AM
bm3r's Avatar
isnt it illegal to put a motor in your car thats older than the car itself?
redDAinteg
07-29-2005 07:14 PM
tgreaves
06-28-2005 05:36 AM
Jockobo
02-17-2005 09:26 PM
Quick Reply: ls swap question
