LS distributor question
Will an OBD2 B18B1 dizzy work with my B18A1 engine? I plan on running a P75 ECU which is OBD1 I believe, or do I need to get an OBD1 B18B1 dizzy?
Re: LS distributor question
they are all the same obd2 and obd1.. the only difference is the wiring.. obd1 had 2 separate wiring plugs where as obd2a has 1 big plug.. they all use the same wires.. you can actually cut and solder them to fit into an obd1 wire harness..
here you go buddy..
http://www.phearable.net/tech/wiring...istributor.jpg
here you go buddy..
What car do you have btw?
As for a 93 civic.. is it an si model? or standard vx, cx etc.??? well if its the si model then your in luck.. You dont have to modify your engine harness for the sensor plugs to work. But if you want you can always get an obd1 gsr engine harness.
