Low pitch Squeaking noise coming from the rear 1999 civic.
I have this low pitch squeaking noise coming from my rear passenger side. The weird thing is when I drive my car for the first 20 minutes everyday it doesn't make any noise then after a while it starts to make the noise. its been at it for about a week now and usually only occurs when im going around 30 mph and also when I start to slow down. Everyday I drive it it sounds fine but after a while it starts to act up, any information you guys could input?
Here is a link of the noise, I believe this is under the Trailing arm? correct me if I'm wrong.
https://www.facebook.com/photo.php?v...55446839344556
Re: Low pitch Squeaking noise coming from the rear 1999 civic.
I have had this problem for too long!! Recently I read that it could be the strut mount so you can put the one from the other strut on and see if the sound prevails
How long have you had your car for? original suspension? mileage?
I had a similar noise to what your car makes and it turned out to be that all the rubber pieces were old and or busted. My rta's were bad, rear rubber spring mounts were cracked, bump stop were garbage. I purchased my 2000 sedan about 2 years ago and the owner said all 180k miles were from home to work 60 miles round trip.
redm3turbo
12
06-11-2011 04:35 AM
ibanezrgking
05-19-2002 08:29 PM
