Manual Pedal Assembly
Hi everyone, I'm doing a auto to manual conversion. I got everything I need except the pedals.... By any chance does EG or DC2 manual pedals fit in a 98 EK.... Looked across every thread and no answer.
Fish Twig
Re: Manual Pedal Assembly
It'll fit but if you're gonna use the eg/dc2 gas pedal than you might need to change the throttle cable. The way the 96-00 civics holds the cable is different from the 92-95 civics
Thanks tony, anybody else knows if for sure they'll fit? It's hard to come across EK pedal assembly in south Florida. And dc2 and eg pedals are the same right?
Seagull Management
The clutch pedal is the same, the brake pedal isn't. However I think you can swap the pedal arm itself from a set of EG/EK pedals to the old automatic EK pedal bracket. Keep the EK gas pedal, they're the same between automatic and manual (EG/EK aren't btw)
Fish Twig
If you just install the clutch pedal you should be fine, just don't swap all of them, or install clutch pedal and swap brake pedal because the automatic brake pedal is different from the manual brake pedal.
anyways I got my manual pedal assembly off of an EK
and for deschlong good that you didnt take it in a negative way it was never meant to be a c unty remark lol, have an awesome day bro thanks for the help.
Fish Twig
Its not the height but length of the auto pedal vs the manual pedal. I'll take pics tomorrow. I just pulled the dash and pulled the firewall harness. I'll try to finish doing my replacement of the firewall harness and pedals tomorrow.
Fish Twig
My idiotic *** thought the RHD pedal assembly would work on the LHD cars, nope. So off to the junkyard again. But yes if you install the clutch pedal and not switch out the brake pedal it will sit really close. I did find an image of both the manual brake pedal and automatic brake pedal for you.
http://www.6thgearadvertising.com/ci...l/DSCN2008.jpg
tegboy321
10-04-2012 12:28 AM
93eg2james
08-18-2006 08:55 PM
ScottEK
05-09-2006 05:35 PM
