Low Idle Issue Del Sol.
Straight to the point.
DEL SOL (B16A Swap)
I've recently been having some Low Idle issues randomly. Mostly Occurs when engine is Warm. To the point were engine turns off on me.
ECU is throwing a code 10. (IAT) but I dont have/see an IAT.
Looked up forms but theyre just throwing me in different directions so i thought I'd ask for help directly!
THANKS IN ADVANCE.
Video Below v v v v v v v
DEL SOL (B16A Swap)
THANKS IN ADVANCE.
-Intl Steve Krew
Re: Low Idle Issue Del Sol.
Pics of your hanging plugs.
Yes you need the IAT.
After that's in you need to reset the idle, by putting the ECU into diagnostic mode, unplugging the IACV, and then adjusting it to the proper idle speed.
Once you do that you need to do an idle learn procedure.
After that it should idle at the proper speed needed. I believe that is 750+-50 but I am not sure.
You can if u want to. Or just poke a hole in your intake pipe, insert iat, zip tie it to the intake tube. Extend the iat plug wires to reach iat sensor at the intake tube. Done.
tgordenDELSOL
10-12-2014 11:26 AM
pdiddy
12-10-2002 10:47 PM
