Loss of Power, then no start
Old 07-02-2009, 02:50 PM
jawsiiv's Avatar
Default Loss of Power, then no start
Car Problems as So....
Bad Rings
Car ran fine, except for burning of oil due to the rings when suddenly I started having loss of power. THis was last week. THen this week still continuing loss of power, I drive it on the high way and it begins to die. Car will not turn over. Fuel pump is priming, no CEL going on either. Change plugs, wires and distributor with no success. I am changing the fuel filter now.
What could be the problem???
Also could the exhaust be backing back into the engine, I have a silencer on my muffler.
Thanks in Advance
Old 07-02-2009, 03:00 PM
Ruben19's Avatar
Default Re: Loss of Power, then no start
do a compression test.
Old 07-02-2009, 03:53 PM
jawsiiv's Avatar
Already know that Cylinder two is bad due to the oil on the spark plug
Old 07-03-2009, 05:07 AM
alexbig6's Avatar
my car was doing almost the same thing when my ignition coil went out
Old 07-03-2009, 03:57 PM
jawsiiv's Avatar
I have tried two different Distributors, so its not the coil. Alternator is good, Battery and Fuel Filter are good. Its getting air. ECU is good. Starter is good, only thing left is the freaking Injectors
Old 07-07-2009, 09:56 PM
jawsiiv's Avatar
Bump,
Checked timing, is on, getting fuel, spark and when i try to start it, and give it full open throttle, it seems like it wants to start but doesnt.
Help. Tried 3 different ECUs also.
Old 07-07-2009, 09:59 PM
RondatheHondaSI's Avatar
injectors? i had the same problem
Old 07-07-2009, 10:03 PM
Former User's Avatar
Originally Posted by jawsiiv
Bump,
As already mentioned, compression test the cylinders.
Old 07-08-2009, 03:42 AM
MHDesigns's Avatar
oil on the plug could also be a bad spark plug seal.
Old 07-08-2009, 10:17 AM
jawsiiv's Avatar
UPdate... compression test.... Cylinder 1 and 2 are at 0 and 4 was at 20...Guess I gotta throw my project engine in there....There goes my weekend..
Old 07-08-2009, 01:03 PM
viskii420's Avatar
was the car cold when you did the test?
all plugs were out?
battery had juice for strong crank?
Old 07-08-2009, 06:52 PM
jawsiiv's Avatar
Car was summer temperature, all spark plugs were out, and i used a FRESH Battery for the crank. I ran the test several times.
Explains everything, the ring probably just went out thus, no compression. Only plug that had dust on it was the 3rd one, which means 1,2,4 were doing nothing.
Jakroy
02-19-2017 04:38 AM
aptyk88
25
09-11-2008 10:14 AM
dwaynevkao
09-06-2006 07:28 PM
Marcj822
12-03-2005 07:38 AM
Quick Reply: Loss of Power, then no start
