Loss of Power, then no start
Car Problems as So....
Bad Rings
Car ran fine, except for burning of oil due to the rings when suddenly I started having loss of power. THis was last week. THen this week still continuing loss of power, I drive it on the high way and it begins to die. Car will not turn over. Fuel pump is priming, no CEL going on either. Change plugs, wires and distributor with no success. I am changing the fuel filter now.
What could be the problem???
Also could the exhaust be backing back into the engine, I have a silencer on my muffler.
Thanks in Advance
Bad Rings
Thanks in Advance
Re: Loss of Power, then no start
I have tried two different Distributors, so its not the coil. Alternator is good, Battery and Fuel Filter are good. Its getting air. ECU is good. Starter is good, only thing left is the freaking Injectors
Bump,
Checked timing, is on, getting fuel, spark and when i try to start it, and give it full open throttle, it seems like it wants to start but doesnt.
Help. Tried 3 different ECUs also.
UPdate... compression test.... Cylinder 1 and 2 are at 0 and 4 was at 20...Guess I gotta throw my project engine in there....There goes my weekend..
Car was summer temperature, all spark plugs were out, and i used a FRESH Battery for the crank. I ran the test several times.
Explains everything, the ring probably just went out thus, no compression. Only plug that had dust on it was the 3rd one, which means 1,2,4 were doing nothing.
dwaynevkao
09-06-2006 07:28 PM
