Looking for Electric Window Roll-up diagram for door
Old 02-24-2016, 06:37 PM
  #51
GearHeadDriver's Avatar
Default Re: Looking for Electric Window Roll-up diagram for door
To clarify, D has continuity when the car is off. It does not when the car is on.
Old 02-24-2016, 06:42 PM
  #52
Former User's Avatar
With relay removed?
Regardless, do the tests above in post #50 first.
Old 02-24-2016, 06:45 PM
  #53
Yes, relay is removed. I will do tests as suggested in post #50. It'll have to wait till tomorrow afternoon.
I'll update as soon as I get home!
Old 02-25-2016, 03:08 AM
  #54
canadaek's Avatar
If your friend used 96-00 wire harness it's very likely that they didn't plug into the factory location on the fuse block . Maybe your friend who did the conversion could shed some light on the wiring ! Or trace wires from the door plug to see where they end up
Old 02-25-2016, 07:17 AM
  #55
The issue has been resolved this morning. I took a look at the connectors again on both the driver and passenger side door. Specifically, I looked at the switch that rolls the window up and down. I noticed a little corrosion on the inside of the plug. I cleaned it up a little bit and plugged them both back in. Everything started working after that.
Thank you so much for the help and continued patience from the members on this forum. This was a huge relief for me. Now I can move along and get the last few things done and finally patch up this car.
I have to put the spotlight on RonJ for a quick moment. Thanks again for all your help. You're exceptional when it comes to troubleshooting in all areas. You've been very patient. Much appreciated! By the way, where did you get your online service manual from? I'd like to nab a copy.
imonx850
12-05-2010 08:22 PM
CiViCBruh
01-30-2008 09:01 AM
INVALID
10-28-2006 03:54 PM
vtec_hatch
01-30-2006 01:02 AM
Quick Reply: Looking for Electric Window Roll-up diagram for door
