Looking for Electric Window Roll-up diagram for door
I have a 95 Honda Civic Hatchback VX. My friend swapped the power windows from an EX Coupe and installed it in my car. My car came with manual windows. It was a pretty flawless install, except he didn't mount the window control box to the door. I tried looking up the door diagram for an EX and I can't seem to locate where that box mounts to on the door.
Would anyone happen to know where these boxes get mounted? Currently they are literally just hanging behind the door panel. I'd like to mount them properly.
Thanks in advance.
Thanks in advance.
Re: Looking for Electric Window Roll-up diagram for door
Doesn't sound like it's from the 5th gen.
When I looked into my books, the control unit is built into the driver side switch. So you have the driver side switch and then the motor. Those are the only two components on the 92-95 power window units from what I can find.
The 95 EX CDM I have downstairs doesn't have power windows, just power mirrors. So once again, I tend to think the setup you have was pulled from a 96-00 EX not a 92-95. That would explain no OEM mounting location on the door.
Actually the FSM for the 96-00 shows the same thing. The control unit is integrated into the driver side switch panel:
That's not what I have though.
Maybe I'm thinking of the power supply for the power door locks? That was swapped to my EG as well.
I never narc'd on nobody!
Oh boy are you in for a fun time. The only control box is built into the driver's door switches. It's all a relay system.
Attachment 515841
Attachment 515842
Attachment 515841
Attachment 515842
Unfortunately, I just plugged the switches back into the wiring harnesses and the windows / door locks don't function anymore.
Sigh.... Very disappointed. I have appointments which require them to be working tomorrow.
Any idea's on where to start? Both doors are plugged into their respective window controller. I also plugged in the Unlock/Lock switch for the driver side. Isn't that it?
That statement was correct until I tried it again tonight. It had been working since it was installed late last year until after the glass in both doors were replaced. The glass was done roughly 1-2 months ago. At that time, I had asked the installer to leave the door panels off. That was the last time they were seen working.
The install wasn't clean, but it was working.
I checked all the fuses under the steering wheel and none were blown.
I'll try looking at the jambs again, but from what I could tell it was OK.
They only took off the door panels. The only plugs that came off was the Unlock/Lock button and the window roll up/down buttons for the driver side. On the passenger side there is only the window roll up/down button. I plugged all those back in and nothing happens. The plugs are pretty straight forward.
I was replacing the door panels, so I had asked them to leave them off when they were finished replacing the glass. I don't believe they did anything wrong.
Have you specifically checked the master window switch connector, the door lock actuator connectors, the window motor connectors, the door jamb connectors, and the window and lock fuses?
The master switch connector is this? Yes, I checked the plug on the driver and passenger side.
(Picture is for reference only. It is not my car model.)
Where is the window and lock fuses? I only checked the fuses that were in the main panel under the steering wheel. If this setup has it's own spot for fuses because my car did NOT come with power windows, etc. then I have not checked them. The connectors on all the other components are plugged in securely.
Look up the window and lock fuses in the manual and then check whether fuses are installed at those locations. If so, as is likely, voltage test them.
https://honda-tech.com/honda-civic-d...fuses-3079359/
