A little help?
A little help?
I was wondering if you guys think this is a good deal. I looking to start a motor project in a 97 coupe and I found a CRV (b20z) motor with 105K miles on it for $500. Problem is it will need the following to get it running. Motor Mounts, SI bracket for Mounts, ac conversion bracket, power steering bracket, (JDM) jumper harness for ECU, axles, Phearable ECU, tranny, clutch, front and rear main seals, oil pan gasket, valve cover gasket, dist. O-Ring, exhaust cam seal, head gasket, & APR studs and bolts. Good things are that it just had the timing belt replaced and I have seen the motor run, but I think the guy may be asking a little too much. This is my first encounter with this motor so I thought I would ask the pros.
Re: A little help?
I second that. I researched my D15B swap for like a whole month(not on H-T) before i settled on it. To buy a swapped car is a gamble if you don't know ALL you can first. I.E. my bro bought an h22a swapped accord for $750 and it had wiring issues out the a$$,and a bolt where the V-TEC oil plug goes??wtf?
Re: A little help?
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
