Lights Won't Dim!!!
Lights Won't Dim!!!
Yeah, usually people have issues with lights dimming because of bad ground. When I turn on my headlights, my gauge cluster doesn't light, and my heater control doesn't dim. WTF should I check first. Trust me, I've checked.
Re: Lights Won't Dim!!! (O RLY)
Your dimmer switch is bad. Get a used one off of ebay. I had the exact same problem. The dimmer switch is common for going bad.
Re: Lights Won't Dim!!! (spoonracer84eg)
If you have an eg here you go...
http://cgi.ebay.com/ebaymotors...wItem
Make sure you ask if the dimmer switch works.
I really don't think its the dimmer switch though. It may be, but are there any fuses or relays I can check.
I believe the fuses are under the dash drivers side. I didnt think it was the switch either. I waisted my time pulling the cluster out and checking grounds and all it ended up being was the switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg »</TD></TR><TR><TD CLASS="quote">Do your dash lights work with the headlights off??</TD></TR></TABLE>
Yes, they do.
Yes, they do.
slammedef06
01-31-2005 06:54 PM
E Swift
12-17-2002 03:51 AM
