lifter tick help!
Old 03-09-2003, 09:16 PM
Slow Egg's Avatar
Default lifter tick help!
i have a d16 sohc vtec. i hear my lifters ticking slightly,what can i do to make this go away so i wont have further problems?????
Old 03-09-2003, 09:18 PM
Chris y0!'s Avatar
Default Re: lifter tick help! (fortunecookie)
you must have one of those rare pushrod d16s
anyway, how many miles are on the motor?
[Modified by Spoon Hybrid, 6:21 AM 3/10/2003]
Old 03-09-2003, 09:23 PM
Slow Egg's Avatar
Default Re: lifter tick help! (Spoon Hybrid)
rare?pushrod?is that good. hmm about 200k. but it was fully maintainded and runs fine.had it since june of last year and nothings been wrong before.previos owner was 1st owner and took great care of it?the car is quick and you cant tell it has 200k miles on it
Jon Black's Avatar
Uhmmm...adjust your valve lash...its in the repair manual.
Jon Black
Old 03-09-2003, 09:27 PM
coldfiremx's Avatar
Default Re: lifter tick help! (Jon Black)
hey man i got te same sound, but i only heard after i put my headers on, weird but i dunno, doesn't affect the performance and i have only 56k miles
Old 03-09-2003, 09:31 PM
Slow Egg's Avatar
Default Re: lifter tick help! (coldfiremx)
im nervous bc my friend had a 97 civic and had bad lifter tick and later within a month blew up...ahh my one friend said to add auto trans fluid to my motor, left it ruun for 25 mins and then drain, and then change the oil... btw my car is 5 spd
[Modified by fortunecookie, 6:32 AM 3/10/2003]
Old 03-09-2003, 10:45 PM
M-EJ1's Avatar
Adjust valve lash, you'll have to look at a manual for the details.
Also, another thing to remember is that you'll always hear SOME clicking, as your injectors make some noise when they pulse (mine do at least, and so do my DSM 450cc's, but they're much louder)
Old 03-09-2003, 11:04 PM
romeo619romeo's Avatar
Default Re: lifter tick help! (M-EJ1)
might also be your injectors ticking...if you rev high often..
Old 03-09-2003, 11:51 PM
Jon Black's Avatar
Sounds like you may have a small exhaust leak.
Jon Black
Old 03-09-2003, 11:53 PM
Jon Black's Avatar
If it sounds like a sewing machine, you just need to adjust your valve lash. Its easy to do and takes about 30 minutes. It wont hurt it too much if your dont do it.
Jon Black
Old 03-10-2003, 07:18 AM
Slow Egg's Avatar
thanks for all the help
Old 03-10-2003, 05:46 PM
idontcare's Avatar
what repair manual would i look in learn how to adjust valve lash. cause my z6 has only 39xxx and its makes a slight clicking sound. thinkin its my valves. is there ne online manuels i would use..or do i have to buy the manuel?
Old 03-10-2003, 05:48 PM
Chris y0!'s Avatar
Default Re: lifter tick help! (idontcare)
adjusting valves isn't hard, but you should still have a manual for more involved things.
http://www.helminc.com
caideN
Honda CR-V & Element
11-26-2014 01:27 AM
1988HondaHaTcH
12-07-2006 07:57 AM
UeyeMYsi
Honda Civic (2006 - 2015)
10
06-12-2006 09:06 AM
BigMoose
09-30-2005 05:31 PM
Karyn
12-02-2003 07:00 AM
Quick Reply: lifter tick help!
