LED Instrument Gauge Light Replacement
Has anyone tried using Led #74 cluster bulb replacements on there Honda 95 or older. Im thinking of trying these ones out, since the ones I have in are so dull. If so does anyone know where you can get them around Canada, Toronto area?
http://www.superbrightleds.com...pping
i have them right now. if you do order from them be sure to order the bulbs with the holders because it's a pain tryin' to fit those LEDs onto the OEM bulb holders.
oh, and also since they'e LED bulbs they don't disperse as well as regular bulbs meaning there's some areas that are kinda darker and some that are brighter.
i wouldn't recommend getting them unless you know how to do it so that the cluster is evenly lit (somethin' to do with drilling a hole and putting another bulb in there and etc.)
if you don't mind uneven lighting then by all means go for it.
Re: (DEIVIONCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX »</TD></TR><TR><TD CLASS="quote">if your carefull you can sand the head of the led flat and it should diseperce the light alot better</TD></TR></TABLE>
i dident know you could do that.
Re: (skater5067)
As long as you don't sand it way down there's no problem with sanding.
I just ordered some LED's with holders for mine that have a domed top to diffuse the light, I'll let you guys know how it comes out.
PhatBoiOnDiet
01-27-2013 07:02 PM
