Can Gsr Sway bar fit an EX civic?
what size is ex sway bars (rear)?
will it just bolt up normal?
thinking of upgrading mines and giving mines to my friends
Re: Can Gsr Sway bar fit an EX civic? (DragII)
If it's a 92-95 EX then you got to switch to 94 and up integra gsr lca's.
And you'll need the entire swaybar assembly ("endlinks", subframe brackets, D-brackets w/ bushings, ETC....)
On the 96-99 EX i'm pretty sure the LCA's are setup for a swaybar, but you'll still need everything else.
Hope this helps......
Re: Can Gsr Sway bar fit an EX civic? (EJ1)
its a 96-98 civic coupe ex
the suspension is differnt?
from a SI?
what would i need to mount the GSR sway bar there?
from a SI?
Richard.
06-27-2007 08:59 PM
