kickin transmission
kickin transmission
i have a 93-94 honda civic ex automatic transmission,but it switch gears it kicks back hard then goes into gear .what could be the problem with
Re: kickin transmission (menito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menito »</TD></TR><TR><TD CLASS="quote">i have a 93-94 honda civic ex automatic transmission, but it switch gears it kicks back hard then goes into gear .what could be the problem with</TD></TR></TABLE>
You check your tranny oil? Could be low
d series autos shift kind of hard/crisp to begin with. i had an old worn mount and the tranny was hitting part of the body. if yours is moving too much, might try some urethane motor mounts- no more hitting since i put some in
did you use the right tranny fluid? modern trannys shift smoother with a addetive in the fluid, using a old fluid will make it shift harder, but will be okay on the tranny. im guessin you should use dexron 3 or dexron 2e
mr. goodwrench
01-18-2006 01:59 AM
f150harleytruck7
07-13-2005 04:04 AM
