just installed apexi ws
I just put on the ws and i love it. Its quiet while cruising and has a nice sound when getting on it.
I just wanted to say thank you to all the members that recomended it to me
Re: just installed apexi ws (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">does WS have resonator??</TD></TR></TABLE>
Yes, i believe it does. My buddy has one on his Prelude and it sounds good. I'm seriously leaning towards getting rid of my Tanabe SRM and buying a WS.
Modified by SASIR2 at 7:03 AM 12/30/2003
glad to hear you like ur ws. now do you have enough clearence on the rear muffler flange connection? on mine.. the flange after tightened was leaning up against my gas tank. please let me know if had that problem? thanks!
Re: (AzCivicCpe)
yeah.. actually i had it one at first and then i took it off my car.. becuase the flange rubbed off the tar that is covering the gas tank. so i'm gonna try something new like bending the rear section b-pipe and see if that will fix the problem. at first i used some exhaust rubber hanger to put in between the pipe and the gas tank.. but that only lasted so long before it started degrade and melt.
as soon as weather gets better here in cali.. i'll post up some pics after i try to reinstall it. hopefully it will provide solution for everyone else that had that problem.
i've call apexi many times about this problem.. and they said it's due to my installation fault. yet many other of my friends had the same problems. if this is not fixed.. it could lead to a ruptured hole in ur gas tank. i think someone should really get on apexi's ***** about it.. cuz my friends and i did that.. and no effect yet. thinking about going to BBB.
1 Post
Re: just installed apexi ws (tibbor)
Glad to hear that you like your WS - I considered that and the Thermal Classic - ultimately decided to go with the Thermal because of its' slightly deeper tone..
Re: just installed apexi ws (Grimm)
i have one for sale on my 00 civic hatch look here in the classifieds
https://honda-tech.com/zerothread?id=709445
Re: (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">My WS has 3 sections. The section after the cat, the mid section, and the axleback section. I flipped the mid section around and it eliminated the rubbing.
So I guess the rubbing is from an install error. Makes sense to just flip that section around
Re: (tokyoracer)
its a design flaw on the exhaust that it rubs the gas tank. **** APEXI. they cheap out by making the exhaust span 2 generations (93-98 coupes) rubbed on my 5th gen EX, sold that POS and bought a RSR Exhaust, much better quality and still had a great sound...and it ACTUALLY FIT!
I think that Apexi sounds great.....but they are not made to specifications for each vehicle thus causing the exhaust to be modified or cut and welded on.
I think I might go skunk2......we'll see
Good choice though.....does have a very good sound
Re: (dwnthehatch)
yes, likewise all WS for the coupe has 3 sections. however the midsection, if i were to flip it around... it would not connect to the b-pipe from the cat. unless if you had totally flipped that section as well. there are two hangers on the b-pipe from the cat. how did you hang yours?
if you lay the pipe down... there should be 2 hangers, from the top down view.. it should look something like this / \ or like this \ / . so can you tell which way does your hanger look like when you hanged it to the existing hanger on the car??
i believe this is the important part, because depending on how you hang it.. will determine how u can install the mid-section pipe.
Re: (haloseven)
yes i've heard of the same thing... i think apexi just used the same design from 5th gen and just applied it to 6th gen. i've heard of the same problems with the RS-R EXMag on the 6th gen coupes as well.
Re: (dwnthehatch)
i know that the b-pipe has the hanger bracket welded on. but what i want to know is how did you hanger bracket look like from the top down view... either / \ or \ / u know what i mean??
Re: (tokyoracer)
I see what you are saying now. I'll take a look under my hatch when I get home this evening. Send me an email at dwnthehatch@yahoo.com and I'll respond with some pics.
Re: (dwnthehatch)
thanks man.. i'll be working on my car tonight... so i'm gonna try it again and see if it works this time.
for those of you that is confused about what i am talking about... here is what the exhaust looks like when it is installed. this is what i mean by hangers looking like / \
here is the pic...
Modified by tokyoracer at 11:42 AM 12/30/2003
here is the pic...
