it just died!
Old 07-09-2003, 08:36 PM
anotheredhatch's Avatar
Default it just died!
two weeks ago i swapped a B18B1 into my 93 hatch. it's been having idling problems and dies at idle sometimes. and today i was on my way home from the beach at a red light and she died! but this time she wouldn't start back up like usual. so i had her towed back to my house and still can't figure out why she won't start. the motor is out of a 94 integra Ls with 25,000 miles. when she did idle it was at about 1,000 rpms and ran hella strong. PLEASE HELP!!! with any ideas, would be very helpful.
Old 07-09-2003, 08:39 PM
CivHatchH22's Avatar
Default Re: it just died! (anotheredhatch)
thats gotta be embarrasing.. lots of car behind you?
Old 07-09-2003, 08:41 PM
4DRPIMPIN's Avatar
check to see if it is gettin gas and spark first, then check voltage..
Old 07-10-2003, 07:22 PM
ar0nic's Avatar
agh today! wtf that sucks i just emailed ya bro.. get in touch !
Old 07-10-2003, 07:24 PM
New User
ELUD THS's Avatar
Default Re: it just died! (ar0nic)
did you check the alternator?
Old 07-10-2003, 08:39 PM
Dancing is Forbidden's Avatar
Default Re: it just died! (ELUD THS)
hmmmm. Not too sure what your problem is. Just bumping for a local.
BTW-> Greg, what tranny did you use on your swap?
Old 07-10-2003, 09:08 PM
Global Moderator
Jimmy's Avatar
Default Re: it just died! (EF9_SiR)
same **** happened to me also...
except i was ''suppossed to be picking it up from the body shop'' got there and all it would do is turn over it wouldnt crank up..i was getting fuel and spark...and then the next morning i guess from trying to start it so much the battery drained over night and then i woke up and it wouldnt start...now i charged the battery and its i guess temporaily[sp] fixed
Old 07-10-2003, 09:17 PM
allmtr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELUD THS &raquo;</TD></TR><TR><TD CLASS="quote">did you check the alternator? </TD></TR></TABLE>
thats what i was thinking. but check the spark and fuel and get back to us
Old 07-10-2003, 09:21 PM
HatchSpeeD's Avatar
Damn, that sux bro. Nothing worse than just doing a swap then engine probs...troubleshoot man.
Old 07-10-2003, 09:32 PM
well today i tried jump start it and it fired right up like nothing was wrong. so i let it idle in my garage for about an hour, it ran great.so then i turned it off and tried to restart it and there was no power no lights or anything so i hope that it's just the alternater.. i'll find out tomorrow. it's only been two days but i realy miss driving my car.
and i used a manual LS tranny,i tried to get a b16 tranny but they were hard as hell to find, and when i did find one they wanted a lot of money for it
thanks for all the help and any other ideas would be nice, you know just incase
Modified by anotheredhatch at 5:27 AM 7/12/2003
Old 07-10-2003, 09:33 PM
careawholelot's Avatar
Default Re: (HatchSpeeD)
my day is even worse got done doing everything with my b18b into my 94 cx and went out to drive it, my first time ever driving it and i go about 1 mile and my car dies i pop the hood and i see liquid pooring out dont know where its from, i thought it was brake fluid because i just got finished with bleeding the brakes before i took her for a ride, well i managed to start the car don't know why it died in the first place, so i get home look to find where the leak is coming from, turns out one of the tranny bolt was loose i go to tighten it and the tranny case breaks on me i don't know what to do i'm pretty sure i need a new tranny, tranny fluid keeps leaking, i'm so stressed out i think i'm gonna get a type r tranny or gsr tranny with type r lsd and sell my car. paid $1300 for the motor and tranny and i don't even get to enjoy driving for more then 10 minutes before the **** ***** me over now since i need a new tranny there goes my money i've been saving up for turbo.
Old 07-10-2003, 10:14 PM
nY's FiNeSt's Avatar
Default Re: (careawholelot)
i'd guess main relay, when it dies or is about to die do you try and rev it back up or press on the clutch and it will not do anything?
Also check to hear when u crank, if gas is flowing by putting your head towards the back where the fuel pump is. I had the same problems and figured out it was my main relay. If it is the main relay, just tap it a few times. Its by your hood release button, when my main relay was dying and my car wouldn't start, i'd nudge it a few times and it's start back up
Old 07-10-2003, 10:16 PM
HAnda-Tech Member
Henry HA's Avatar
Default Re: (nY's FiNeSt)
alternator is my guess if it can run perfect from a jump start
Old 07-11-2003, 03:17 AM
Default Re: (B18C_DC2)
I HAD an extra B series alternator until the other day man. Just sold it. Yeah I got an LS tranny as well, but I think Im skipping the LS route and going big.
Old 07-11-2003, 08:19 PM
Default Re: (EF9_SiR)
UPDATE: he changed the battery, it will now crank but wont start. Is it something in the wiring of the distributor? Thanks for the help.
Old 07-11-2003, 08:56 PM
ninjaMONKEY
Guest
Posts: n/a
Same thing just happened to my dad in his prelude. Check the distributer the coil could be bad.
Old 07-11-2003, 09:01 PM
93egsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_DC2 &raquo;</TD></TR><TR><TD CLASS="quote">alternator is my guess if it can run perfect from a jump start</TD></TR></TABLE>
Old 07-13-2003, 08:39 PM
i put a new distributor on it and it runs like a champ, all fixed now.
im so glad to be driving my car again.
thanks alot for all your help
Old 07-13-2003, 09:38 PM
Spartanic's Avatar
Good to hear that you solved your problem. I just wanted to add that sometimes a small wire grounding on the throttle body housing will come loose causing hard starting, erratic idling and other problems, you may even notice the MPH gauge jumping around. All you got to do is tighten this sucker up and it'll run fine.
pnoi_boi68
04-15-2010 08:21 AM
maGiK6
07-08-2009 03:36 PM
jonoknut
02-24-2009 09:07 PM
mark2583
01-09-2008 03:13 PM
95BlkGSR
01-03-2006 07:04 PM
Quick Reply: it just died!
