JDM ZC no CEL when FP primes, no spark?
i had a problem with the fuelpump now that primes good and everything.
its a JDM ZC SOHC VTEC motor i just timed it after i got the fuel pump working to make sure everything was straight with the timing so that wasnt the problem.
when i turn the ignition key to "ON" my battery light, and clock come on but the check engine light is supposed to come on while the fuel pump is priming. the fuel pump primes but my CEL doesnt appear at all. the light isnt blown. Also the battery light wont go off. Also if i use the jumper for the trouble codes to be displayed the CEL still doesnt come on. I have no spark from the distributor.
all fuses are working and not blown ive used a test light to make sure they were getting power. main relay is brand new.
any ideas or things i should try please give me some clue
Re: JDM ZC no CEL when FP primes, no spark? (92HatchB16)
93 honda del sol SI
ZC SOHC VTEC motor
Z6 tranny, distributor, and manifolds
p28 ecu
my bad thats usually what i put first in the post
ZC SOHC VTEC motor
p28 ecu
InTheLBC20
12
10-02-2009 08:21 AM
ncskate
07-15-2008 05:18 PM
ncskate
08-01-2005 02:19 PM
