JDM ITR/CTR Shift Knob Install: Will knob and boot be attached?
Old 03-15-2003, 02:42 PM
EricUSC's Avatar
Default JDM ITR/CTR Shift **** Install: Will **** and boot be attached?
I will be installing a titanium JDM ITR/CTR shift **** this week along with a CTR shift boot with red stiching. These are the parts I have:
1. ITR/CTR titanium shift ****
2. Locking nut for shift ****
3. CTR leather shift boot w/ red stiching
I noticed that the factory USDM Civic shift ***** have retaining tabs that hold the shift boot to the ****, while the JDM **** doesn't have those tabs.
I have the following questions:
1. Do JDM ITRs and CTRs just come with the **** and boot detached from the factory, or are they connected some way?
2. If they do come connected from the factory, what part do I need to make my shift ****/shift boot setup identical to that of a JDM ITR/CTR?
3. I notice that S2000s have similar shift *****. Do S2000 shift ***** connect to the shift boots? If so, how are they connected?
I want the **** to be connected to the boot, but only by using honda parts. I don't want to use rubber bands or any ghetto rig method. Thanks!
Old 03-15-2003, 04:18 PM
B2FiNiTY's Avatar
Default Re: JDM ITR/CTR Shift **** Install: Will **** and boot be attached? (EricUSC)
Detached.
Old 03-15-2003, 04:38 PM
98EJ's Avatar
Default Re: JDM ITR/CTR Shift **** Install: Will **** and boot be attached? (B2FiNiTY)
In my car I am using a civic R shift boot with a skunk2 **** so my setup is very similar to yours. I wanted the shift boot to come right up to the bottom of the ****. I put the little nut on to keep the **** in place and the plastic part at the top of the boot goes right around it. To keep it up there I just used some electrical tape on the shifter. It may be ghetto but you can't see it.
On the civic type R the shift boot doesn't come all the way up to the **** it sits a little below.
Old 03-15-2003, 04:56 PM
EricUSC's Avatar
Default Re: JDM ITR/CTR Shift **** Install: Will **** and boot be attached? (98EJ)
So let me get this straight. You wrap the tape around the shift lever directly underneath the shift boot, increasing the diameter right underneath the shift **** so the boot wouldn't fall? Doing this requires me to remove the shift boot, right?
Also, I notice that the S2000 has a very similar shift ****. Does the S2000 **** connect to the boot or does the boot sit below the ****? If they connect, how do they connect in an S2000 and can the same part be used on a Civic?
Old 03-15-2003, 05:06 PM
98EJ's Avatar
Yep, you have to take the boot off. I just wrapped the electrical tape around the shifter a couple times when I was putting the boot on. I put the shift boot over the shifter and screwed the shift **** on so I could see where the tape needed to go. As far as the s2000 I'm not sure if the boot touches the ****. On most honda's the shifter just gets fatter and the boot can't go any further down.
Old 03-15-2003, 05:21 PM
Noe Kozz's Avatar
My shifter is detached. I like it better that way. I'm running Skunk2 short shift and ****. When I had my mugen ****, you couldn't see the short shifter since the **** rested at a lower level.
Old 03-15-2003, 05:26 PM
leprechan117's Avatar
Default Re: JDM ITR/CTR Shift **** Install: Will **** and boot be attached? (Noe Kozz)
im running all stock, and its not attached...... is something wrong?? hahaha, not that it reallt maters
Old 03-15-2003, 05:47 PM
98EJ's Avatar
Default Re: JDM ITR/CTR Shift **** Install: Will **** and boot be attached? (leprechan117)
here is a picture from a civic type R
the picture is kinda cut off but you get the point.
[Modified by 98EJ, 2:54 AM 3/16/2003]
[Modified by 98EJ, 2:57 AM 3/16/2003]
Old 03-15-2003, 08:45 PM
EricUSC's Avatar
How do you install the Mugen shift ****? I also have a Mugen shift **** laying around, and it has not threads inside. Do you need glue or something?
MIKEuBEEZY
07-01-2008 01:33 AM
SickSpd06Si
Honda Civic (2006 - 2015)
57
01-08-2007 03:14 PM
johnclaunch
05-24-2006 11:31 AM
K.RigSeg
06-05-2004 05:29 PM
vtec11
10-15-2001 09:27 PM
Quick Reply: JDM ITR/CTR Shift Knob Install: Will knob and boot be attached?
