JDM ITR 5 lug Conversion (36mm hub) + H22 swap (H series end axel) = what axel? & What Axel for D se
Hi I have a JDM ITR 5 lug conversion and a H22 swap being shipped. I don't know what axels to use or what combination of axels to use? I do have the JDM ITR axels with the 36mm hub so is there anyway I could mix and match it work in my H22?
And more importantly...
I am installing the 5 lug now and I have a D series right now. I'm pretty sure B series axels will not go into a D series engine, is that true? If it is what should I do as far as axels until I can swap my H22 in?
Re: JDM ITR 5 lug Conversion (36mm hub) + H22 swap (H series end axel) = what axel? & What Axel for
You are in for some fun stuff! You can make your own
axles that will fit. You need to get the 36mm half and
put it on the d series axle. I have never tried it, but I
have heard that it is what you need to do. Good luck,
dont forget a lot of rags. Those axle projects get nasty.
Thanks so basically just a butchery between my stock axels now and the 36mm hub ends of the JDM axels.
Will it be the same deal when I do the H22 swap; a butchery between the supplied H22 axels and the 36mm hub end of the JDM axels?
Thanks,
Jake
Thanks,
Jake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninety2SiR »</TD></TR><TR><TD CLASS="quote">Thanks so basically just a butchery between my stock axels now and the 36mm hub ends of the JDM axels.
Basically yes. Ive never tried before so im not going
to go into it. Good luck.
Dr. Willy
02-01-2007 10:56 PM
