jdm gsr wont rev pass 3000 pls HELP NEED HELP ASAP!!!!!
Old 07-11-2009, 11:47 AM
gsrboost737's Avatar
Default jdm gsr wont rev pass 3000 pls HELP NEED HELP ASAP!!!!!
so this is the deal im posting this up for a friend he has a 97 civic hatch he had a obd1 gsr swap on but he blew it up so he bought a jdm gsr block from hmotors so he swap tht in n it wont rev pass 3000 like if it reached rev limit he has a 97 gsr ecu with ek harness.
PLEASE HELP NEED HELP BAD
Last edited by gsrboost737; 07-11-2009 at 11:49 AM. Reason: forgot to include year of vehicle
Old 07-11-2009, 12:44 PM
gsr96cx's Avatar
Default Re: jdm gsr wont rev pass 3000 pls HELP NEED HELP ASAP!!!!!
any cell? check tps and map sensor. Is the new motor a obd1 or 2?
Old 07-11-2009, 01:49 PM
my friend said no cel lights n its a jdm obd1 motor we r gng to swap tb cause i also have a gsr to see if its the tps
Old 07-11-2009, 02:01 PM
lsfreak90's Avatar
Had the same problem when I did my ls swap in my last hatch. I broke the sensor on the back of the intake I just can't remeber which one it was. But it worked fine after that
Old 07-11-2009, 02:06 PM
is it the tps or map?
Old 07-11-2009, 04:28 PM
from some weird reason a came upon a thread whr a prelude had the same problem but isaid something abt the vtec system so we swap the vtec solenoid from a usdm gsr n it work crazy but it did.
Old 07-11-2009, 06:33 PM
redline7070's Avatar
did you bypass the crank senor ? you have to if you are running a jdm motor
RWD_DC2
15
01-28-2013 10:12 PM
db1_jdm
12-21-2007 07:17 PM
jedsus
08-16-2006 04:36 PM
91crx but i heard vtec
12-12-2003 11:49 AM
Quick Reply: jdm gsr wont rev pass 3000 pls HELP NEED HELP ASAP!!!!!
