jdm d15b vtec head/built y7 block - Which headgasket and water pump should i use?
Old 11-28-2012, 09:24 AM
98.4DR.EK.D16's Avatar
Icon2 jdm d15b vtec head/built y7 block - Which headgasket and water pump should i use?
I have a jdm d15b vtec head on a built y7 block. Which headgasket should i use? Which water pump? Im assuming a y8 water pump for more teeth but i don know which gasket to get. Obviously oem honda but for which motor?
Thanks in advance
Old 11-28-2012, 09:28 AM
Man U FTW
Schister66's Avatar
Default Re: Which headgasket and water pump should i use?
For a higher-revving setup, you want the gear with more teeth...to a degree. I'm not sure if this is an issue with the D series, but with a GSR vs LS water pump, if you run an LS pump and rev it beyond its effect limit (~7800rpm) the pump can cavitate...meaning its not pumping water because the blades of the pump are moving at such a rate that it causes the coolant to boil in the low vacuum pocket on the lagging edge of the pump blade.
At least on B-series, the t-belt length is determined by the head and waterpump. If you run a GSR head, run a GSR water pump and the t-belt will fit...I can't say I know the formula for the D series, but someone else will chime in.
Old 11-28-2012, 10:36 AM
Its for a turbo application. I have shot peened rods and srp turbo pistons. Since i have a stock head what would you suggest as a rev limit? I was thinking 8000 rpms would be good but i dont wanna risk anything since its my daily
Thoughts?
Old 11-28-2012, 10:38 AM
Also do you know the rated hp for shot peened rods? Im hoping on breaking 300whp. Anything after 300 and id be happy but i dont wanna compromise the rods either
Thoughts? And thanks for the answer and thanks in advance for these questions lol
Old 11-28-2012, 01:18 PM
Default Re: jdm d15b vtec head/built y7 block - Which headgasket and water pump should i use?
bump for assistance?
Old 11-28-2012, 02:02 PM
Man U FTW
Schister66's Avatar
Do you have shot peened LS rods or D series rods? I honestly don't know what they're "rated" at, but I would think you should be fine. The stock bottom ends will make mid 200's before they start bending rods.
ranta18
11-12-2009 08:04 AM
freddysEF
01-03-2007 04:53 AM
dartdc97
10-27-2005 01:08 PM
ef-you
08-06-2004 06:17 AM
Dorikamu
09-25-2002 07:44 AM
Quick Reply: jdm d15b vtec head/built y7 block - Which headgasket and water pump should i use?
