jdm d15b Vtec-E HELP!
Here is my setup
JDM d15b VTEC-E engine
Cx intake manifold - which i beleive has no EGR
P07 (vx ecu)
cx harness
5 wire o2 sensor |- repinned ecu harness, and ran wires directly to sensor-]
Alright now
I am throwing a code 48 (keep reading)
I have read that this is a bad o2 sensor
BUT
could also be the heating element?
I am wondering a few things....
1- could this code be thrown from not having the VX manifold/vtec-e manifold with the EGR
2- could i have wired this wrong?
I have the yellow wire off of the o2 sensor run to a grounding point inside the engine bay... will this work? or does it need to ground to a wire off the ecu.
3- could this be caused by an exhaust leak of any kind?
4- would this motor cause this? since its running a p07 USDM ecu on the jdm vtec-e engine?
any help or ideas are appreciated
I really dont feel like paying $200 for another 5 wire o2 sensor.
thanks
P07 (vx ecu)
cx harness
Alright now
BUT
thanks
yeah apparently in japan there is no D15z1, its just labeled d15b, has a VTEC-E valve cover
but internally etc is the same as the z1
IE, EGR, 5 wire o2 etc...
Re: jdm d15b Vtec-E HELP! (dasistheone)
yea there are 3 JDM d15b's...
SOHC VTEC
SOHC 2 stage Vtec (some people call it 3 stage)
SOHC VTEC-E
my car (d15z1) throws code 12 when the egr isnt connected (lol what luck, code 12 is EGR malfunction)
SOHC VTEC
SOHC VTEC-E
Re: jdm d15b Vtec-E HELP! (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">yea there are 3 JDM d15b's...
SOHC VTEC
SOHC VTEC-E
True, bump for some ideas as I'll be putting this engine in my crx sometime.
SOHC VTEC
SOHC VTEC-E
Alright
well im in the process of putting the z1 style manifold back on, the one with the EGR on it.
Just doesnt make since that im not throwing a code 12 (for EGR) seeing as how i dont have one hooked up period???
Ive read that with no EGR it makes ur car run lean.
Ive also read that if u have shitty gas etc, then u can throw a code 48 due to the engine leaning out.
On the EGR there are 3 wires coming off of it.
And i have only found 2 wires on the ECU pinouts for it.
Is there something it wires to on the firewall first?
prjct92eh2
05-04-2022 11:24 AM
spyderracing
18
10-13-2004 11:17 PM
