is a jdm d15b better than a jdm zc?
i am curious which is the better engine. i will be gettin one soon so i would like to know which is better. i have a d16z with broke rings, so which one has more power, easy swap, and more aftermarket parts. and i heard that i can use all of my d series stuff (header, intake) on the d15b, but it doesn't have a knock sensor.
Guest
Posts: n/a
Re: (jagolas)
It's actual the same same engine just a destroked z6 block and different cam. Sam pistons different crank and rods. Heads are from the same cast. I just picked mine up today from Cyberdx16 for 175 but just need new z6 pistons and some rings and I'm set.
Re: (egizzle6)
yeah i can get all the gaskets, rings, rods, and main bearings for like 215, but i needed some one to do the work bc i have no room and hardly the right tools. plus i have a b18b to trade or sell off
Re: (egizzle6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 »</TD></TR><TR><TD CLASS="quote">It's actual the same same engine just a destroked z6 block and different cam. Sam pistons different crank and rods. Heads are from the same cast. I just picked mine up today from Cyberdx16 for 175 but just need new z6 pistons and some rings and I'm set. </TD></TR></TABLE>
d15b is a vx block with the z6 head but with a crazier cam....also the the height of the block is, i think, a little higher. oh yea, the d15 can be revved higher because it has a better r/s ratio(if im wrong, make it right )
95 honda8
06-16-2008 10:03 AM
