Jacking Up a Car
Jacking Car
Hey guys, excuse the noobish question.
I have a 2000 civic and am wondering what are some suggested jacking points on the car, besides the 4 obvious ones.
Which would be good to use when the car is being raised for a significant amount of time?
How to raise to rotate tires, etc?
I tried to search with no luck. Thanks.
Re: (djsbon)
when i rotate my tires i jack up the frame in between the front and rear tires, i have a del sol, the jack will lift up the whole side of the car....then i put jackstands on the two obvious mounting points in case the jack gives out.
Re: (elevatethis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevatethis »</TD></TR><TR><TD CLASS="quote">when i rotate my tires i jack up the frame in between the front and rear tires, i have a del sol, the jack will lift up the whole side of the car....then i put jackstands on the two obvious mounting points in case the jack gives out.</TD></TR></TABLE>
Me too.
You can also use the rear tow hook and there's a "flat spot" on the fron bumper support.
Me too.
Re: (clm)
i installed a comptech rear anti-sway bar and tie bar a few weeks ago.. yesterday, i jacked my rear end up to rip the heat shield off my muffler... i put the jack on the drivers side, and the passenger side rose up almost just as high . wow. just thought i'd share that, i was so surprised
Re: (clm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm »</TD></TR><TR><TD CLASS="quote">You can also use the rear tow hook and there's a "flat spot" on the fron bumper support.</TD></TR></TABLE>
Ding ding ding. We have a winner. Those are the spots I use, then I put jack stands on the other four jack points.
Re: (swatdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swatdog »</TD></TR><TR><TD CLASS="quote">I bought these things that look like pyramids, four of them. Jack up the car, and put them in the 4 obvious spots.
They look like this:
Those "PYRAMIDS" would be called Jackstands.......lol
Re: (King Tut33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 »</TD></TR><TR><TD CLASS="quote">
Ding ding ding. We have a winner. Those are the spots I use, then I put jack stands on the other four jack points. </TD></TR></TABLE>
ditto, some might have treble doing this if thier car is really really low i used to have a problem doing i that way but that is what the few 2x4's were for
deerman2701
04-09-2008 06:41 PM
integracura
05-09-2006 03:26 PM
