ITR shift linkage too short......
helping a friend do his swap (b16a3 into 95 civic sedan) and he has the bronze ITR shift likage but is about 2 inches too short. Should i cut it and weld it to length or should i look for a different set? Also i know the 94-00 integra's as well as the 99-00 civic si are the same. Also know the del sol vtec ones are different. Damn im stumped someone help...
Re: ITR shift linkage too short...... (hahagasdcrx)
If it's a B16A3 into a EG chassis, the ITR linkage is 100% perfect fit.
There is only 2 reasons that i can think of:
1. You do not really have a ITR linkage.
2. Are you sure the tranny is not in 2nd, 4th, or reverse gears? If the tranny is in gear, it will look like the linkage a tad short.
Re: ITR shift linkage too short...... (Petah)
The stabilizer rod is 2 inches short and so is the shifter rod. Both wont reach mounting points on the tranny when the rear bushing is bolted down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx »</TD></TR><TR><TD CLASS="quote">The stabilizer rod is 2 inches short and so is the shifter rod. Both wont reach mounting points on the tranny when the rear bushing is bolted down.</TD></TR></TABLE>
In that case, you probaly have a D-series linkage. I remember a shop that doens't supply B-shift linkages with their swaps will simply cut and extend the D-series linkage. This is crap! The shifting will feel like ****. I will recommend getting a B-series linkage....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah »</TD></TR><TR><TD CLASS="quote">
In that case, you probaly have a D-series linkage. I remember a shop that doens't supply B-shift linkages with their swaps will simply cut and extend the D-series linkage. This is crap! The shifting will feel like ****. I will recommend getting a B-series linkage....</TD></TR></TABLE>
probably SI-R Cable B series shiftlinkage
Re: ITR shift linkage too short...... (Cnote)
probably the wrong L bracket in the back where the tranny bolts to the rear mount on the frame. If you truely have a TYPE R linkage and the tranny is not in any gear you have the motor installed incorrectly most likely causing it to be too far forward and not fitting the linkage.
Re: (ShadyEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 »</TD></TR><TR><TD CLASS="quote">is itr linkage bronze?? i've never heard of this...</TD></TR></TABLE>
It's not bronze....it's more like this goldish color plating that you get. Like a brand new caliper or bolts when you get a new car.
egvtec
04-27-2012 12:30 PM
Luserkid
11
06-30-2004 04:17 PM
