ITR head on B16..... need a remap?
I know this has probably been discussed loads, but I swear to god I've been searching for the last 30 minutes and found nothing! So I thought I'd just fire away and ask the Q!
I've bought a 99 spec UK ITR head, with cams and all the valvetrain. Aswell as the IM and TB. Now, I also have got an emanage but not installed it yet.
Problem is, obviously I want to install the head/cams as soon as I can, but I can't afford to have the E-manage mapped yet.
So my Q is, with the standard B16A2 ECU, am I going to be running lean at any point if I install the cams and head now? Or should I wait until I can afford to get it mapped soon after?
Obviously I don't want to be running lean and munching the pistons, but I'm desperate to get this **** fitted, it's just sat here looking at me!
Cheers!
Cheers!
Re: (towns)
You should be ok. That head is basically just a better ported version of ur stock head and a little more aggresive cams. Just check ur plugs as long as they look good after u have ran ur car with the head u will be fine.
OK, what should I be looking for on the plugs if it turns out that I am running lean? Will I be OK to give it some abuse or should I try and not VTEC as much as I can?
Thanks
Thanks
mynameizstitch
12
07-22-2009 08:46 PM
