ITR engine harness?
Re: ITR engine harness?
Nope, the Integras have a 2-piece harness (like the 5th gen Civics & Del Sols). The engine harness goes from the engine to the shock tower, and then the 2nd harness goes from that shock tower to the ECU. Where 6th gen Civics have a 1-piece harness (engine to ECU).
So if you have a 6th gen Civic, you'll use your stock harness. If you have a 5th gen Civic or a Del Sol, you'll just plug the ITR engine harness into the stock shock tower plugs.
-running 1997 itr engine harness, what cabin harness will fit because my shell has no cabin harness?
Ideally you'll find an EX or Si harness (just because they have VTEC wired in), though any 6th gen harness will be fine if you add wiring for VTEC and knock. Get whatever you can find.
remoer
05-29-2007 06:40 PM
b18c1eg
05-14-2002 10:42 PM
