integra front break swap
hey, i just picked up a gsr front break setup. it has the hubs knuckles, pads rotors calipers everything, its the whole setup. it looks really straight forward, anything i need to know? or is it as simple as it looks? oh yeah, its on a 94 hatch btw
(integra brakes, not gsr)
Integra knuckles are taller than the civic ex/si ones, so you will need an adjustable upper arm (camber kit) to correct this
Other than that, for what you received, its straight bolt-on, yes.
I really suggest you use at least a 7/8" master cylinder, but recommend 15/16 or 1" if possible...otherwise, the pedal will be very very soft/squishy
Re: (pdiggitydogg)
It's straight foward. However, if you change the prop valve to 4040, give yourself some time to change it. It was a bitch for me. Although I am using a stock 13/15" MC temporarily, it is recommended to go bigger. It doesn't feel soft/squishy as pdiggity said and the small MC can be used if you can't afford a larger one (like me).
Re: integra front break swap (littlegreenb18)
THE BRAKE SWAP IS PRETTY MUCH EASY. JUST GET A SKUNK 2 CAM KIT NEEDED AND THATS IT ,MAKE SURE YOU BEELD THE BRAKES STARTING RIGHT THEN LEFT. ALWAY START WITH THE ONE FURTHER AWAY FROM THE BRAKE MASTER CYLINDER.
Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">1991 Civic EX will have a bolt on 15/16" MC to your stock brake booster. </TD></TR></TABLE>
this is the booster I used on my '93 CX when I swapped to Integra brakes, DEFINITELY firms up the pedal, I highly reccomend it
theguy22
11
10-12-2012 11:09 PM
ninety1_octane
10
05-22-2006 08:23 PM
Cyrus4g63
03-10-2006 08:35 AM
typeeg
12
06-11-2004 04:04 PM
