EG with Integra real disk brakes
92 Civic
Can I use the 99 GSR Master Cylinder and the Proportioning valve if I have an Integra real brake swap or do I need to use something else?
Re: EG with Integra real disk brakes (Cyrus4g63)
You *can* use a gsr master cylinder. However, I wouldn't recommend it though due to the ABS. You will have to re-align one of the brake hardlines in order to bolt up to the master cylinder.
I would recommend using a 94-01 Integra RS master cylinder.
The brake booster goes right in though.
Prop valve and everything else will work.
Re: EG with Integra real disk brakes (poison)
My friend is in the middle of putting 94 integra disk brakes on his 94 civic cupe. He hasn't done the master cylinder/booster yet. Is the 94-01 RS one a 15/16"? Also he would have to take out his porportioning valve and replace it with the RS one or one from a 90-93 non abs integra right?
Corksil
17
12-15-2020 05:44 PM
MAFDARK
Suspension & Brakes
04-19-2009 09:38 PM
