integra front brakes into civic question
i have a 95 honda civic si hatchback that has four wheel disc brakes. i want to do a swap to integra front brakes that i already have in my possession. what i have is the the whole set up from ball joint to ball joint. my question is this: is it necessary to swap the lines and the master cyclinder? or will i be fine with my stock master cylinder and brake lines?
Re: integra front brakes into civic question (AcuraEL)
Not the same and you can put them on your Civic. Use the JDM ITR 15/16 or Integra RS 15/16 Master Cylinder/Brake Booster setup in the future.
Re: integra front brakes into civic question (Migs)
Yeah you'll be fine, I've been running gsr front brakes on my stock cx 13/16ths MC for months now. First thing you're gonna notice is the pedal goes a lot farther down, but you get used to it. Braking is improved, and when you swap out the MC, it'll feel better.
not to sound dumb, but I thought the front disks were the same on civic? no?
These pics are from a 96 civic ex. It was my understnding that the 99 Si's were the same as the GSR's. I'm not sure about the 95 si....
[Modified by mrlegoman, 8:55 AM 2/16/2003]
[Modified by mrlegoman, 8:57 AM 2/16/2003]
New User
Re: integra front brakes into civic question (mrlegoman)
from what ive been told, the front brakes on the anti-lock equiped 5th gens are the same as the integras, but not the cars without antilock.
Re: integra front brakes into civic question (civicjdmgsr)
Re: integra front brakes into civic question (B18EG6)
Is the rotor size the same as the Civic Si front brakes? I have an Si myself and was considering doing this brake swap when it gets a little warmer...just trying to figure out if it's worth it. Also, Tom posted up about using the 1991 Civic EX Four Door master cylinder. It is a direct replacement for the 92-95 Civics MC and it is a 15/16 MC
Re: integra front brakes into civic question (b16a ferio)
no the front civic brakes are not the same size. when i was first looking into it, it was saying all over the net that they were identical but they are not. as soon as you look at the stock civic ones, and look at the integra ones you will be able to tell how much bigger the integra rotor and caliper are. i paid like 170 for the setups. so you guys think my stock si master cylinder will be fine then? thanks for all your help
do you guys know what the size of my stock mastere cylinder is? it is a 95 si hatchback with out ABS.
[Modified by civicjdmgsr, 9:13 PM 2/16/2003]
joprez
05-07-2013 02:54 PM
