Integra Dash in EG No Blinkers!
Guest
Posts: n/a
And yes I have searched, and to no avail. If you know the specific thread that can answer this, please direct me there. I put a 95 Integra dash in my 93 DX HB. I used the Integra dash harness and rewired the grey plug to the civic one for the fuse box. Everything is working fine EXCEPT the turn signals. The hazards work, but when I hit the blinker switch nothing happens. No clicking, no blinking, nothing. They worked perfectly fine before the swap. I even tried using a different blinker arm assembly. Maybe I blew a fuse, but what one? I couldn't find a blown fuse. Please advise! I hate not using my blinkers, I am being forced to be an a-hole. Thanks in advance.
Re: Integra Dash in EG No Blinkers! (rxse7n)
Recheck your wiring. Here's a little writeup from Brandon aka "Poison"
The grey plug has additional pinouts on the Integra dash harness and cannot be used. Just retain the Civic grey plug and match the pinouts.
I am currently making a JPEG diagram for this -- will be up soon.
ONE THING, your turn signals will not work.
Why?
This is why:
The power wire going to the Integra hazard switch is the Yel/Blk wire, where-as the Civic hazard switch is the YEL wire.
Just simply take the Yel/Blk wire from the Integra harness (which is an unused wire from the grey plug), and splice that into the Yel wire on the GREEN plug (the middle pinout YEL wire.
Kaboom -- done.
Why?
This is why:
Kaboom -- done.
Re: Integra Dash in EG No Blinkers! (JDMH22HATCH)
try checking your wiring with this:
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Re: (rxse7n)
that is a common problem, search the archives and you will find your answer. I forget what you have to do but that is what everyone that does a integra dash swap in a civic has a problem with.
b16ferio
02-24-2004 08:35 AM
Enternal
01-06-2003 11:16 AM
