94-up LS Cluster in EG Wiring, Diagram HELP
Ok one of my friends just picked up a 95 cx hatch. He just got a 94-up integra ls cluster for it for free. And he wants to put it in and get it all wired up. Does anyone know how to wire this or is it the same as the GSR cluster??? WHat are the correct ways to modify the LS cluster so that it will fit into the eg dash?? Anything else that he should know would be appreciated.
Re: 94-up LS Cluster in EG Wiring, Diagram HELP (92cxgsr)
i could be an ******* about this and do a search and give you the link like this https://honda-tech.com/zerosearch like most people will do..
but i did this swap in my car and i know there is info on honda-tech.com bout it.. but here is the wiring diagram again for a gsr cluster into a 95 civic ex.. some wires maybe different but its mostly the same... some cutting is required to the make it fit..
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Any diagrams or pic, I remember once a post about a gsr cluster in a eg and it had a link that showed how he put it in and what he had to cut and the whole instalation process. Anyone have that link?? Or another pic or anything???
JDM*BUBBLE
03-29-2004 04:48 PM
Ryan C
13
12-29-2003 04:10 AM
