Integra Cluster into EG . Gas Gauge Doesn't Work???
Re: (beaterdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver »</TD></TR><TR><TD CLASS="quote">did u take the gauge apart before you put it in?</TD></TR></TABLE>
No
No
Re: (electric-boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electric-boost »</TD></TR><TR><TD CLASS="quote">does the gas light work?</TD></TR></TABLE>
No
No
re-check and make sure you re-pinned it in the right spots, and it has the right color wire for the civic gas gauge going into the integra gas gauge pin
Re: (3 3 3)
on your eg side yell/white wire (on the 12 pin side) that should be your gas sending unit wire. i havent looked at my gauge. but looking at the eg gauge cluster the letter f behind the meter stands for fuel. so just look at the integra gauge on the back behind the meter for FU and just follow it to the pin color on the teg side...see if that works
Do you have access to a volt meter? if you do can you tell me what voltage is on the yellow/white wire (teg or civic harness, they should be connected together) with the key on.... it should be between 0 and 4.5 volts. if it's 5 volts or higher that means your fuel sender isn't connected to the gauge. If it's <4.5 volts and your gauge isn't reading and the rest of the gauges work, it's a bad gauge.
Re: (3 3 3)
yea or i could take my cluster out and see which too. but lets see if that works if not get back to me and ill take the cluster out and tell you exactly which one..
Re: Integra Cluster into EG . Gas Gauge Doesn't Work??? (3 3 3)
hey max, i just checked the helms and on the eg side the yell/whit is the gas gauge. so look at the back of the dc2 gas meter and you will see three screws + - and the letter FU and just follow the FU lead to the pin. and that is your gas gauge and should work..
Re: (Relic1)
but the funny thing is, a couple of people i know that did the same thing have the same exact problem as i do. im gonna try that tonight jackie and see if that works.
Re: Integra Cluster into EG . Gas Gauge Doesn't Work??? (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">hey max, i just checked the helms and on the eg side the yell/whit is the gas gauge. so look at the back of the dc2 gas meter and you will see three screws + - and the letter FU and just follow the FU lead to the pin. and that is your gas gauge and should work.. </TD></TR></TABLE>
sweet! i will check it when i get home.
Re: (coma-b16)
dc cluster into eg dash. i removed the cluster cover so i dont have one on right. the bezel doesnt push up because i removed the cluster cover. i also removed the EG cluster mounting brackets.
figured out the gas problem as well. the 2nd pin on the large plug is empty. you need to add a pin and wire it to the yellow/white gas wire.
Hiroshima_VTi-S
05-30-2007 10:35 PM
