okay i just bought some integra rear discs brakes
i just won some integra gsr rear disc brakes for my 92' civic cx hb i know i should probably change the front rotors to bigger ones also now my question is should i just get the rotors and calipers off an integra? and can i use my stock knuckle spindle with out any problem if i just change the rotors and calipers? or would it be better and a lot easier if i just took the whole knuckle assembly off an integra? i know these are a lot of questions but i want it to be coorect the first time so i dont have to do it again a second time thanks for the responses
you will need to change the knuckle.
You can use one off a civic ex/si 92-00 or integra 94-01. (Civic ex/si and integra share the same rotor - integra caliper pistons are larger)
this information has been covered many many times before. please search in the future.
Re: (pdiggitydogg)
thanks for the reply and yes i did do a search before i typed up the post the post but no one seemed to have asked the question specifically like i did so i decided to type it up.
Re: (jpb105079)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">you will need to change the knuckle.
this information has been covered many many times before. please search in the future.</TD></TR></TABLE>
FYI.....the civic ex w/ABS has the EXACT same caliper as the integra RS, GS, LS and GSR
Re: okay i just bought some integra rear discs brakes (jpb105079)
i dunno if you read this, if you haven't you should
https://honda-tech.com/zerothread?id=152884
Re: okay i just bought some integra rear discs brakes (CivicVX94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 »</TD></TR><TR><TD CLASS="quote">i dunno if you read this, if you haven't you should
https://honda-tech.com/zerothread?id=152884</TD></TR></TABLE>
good link
good link
i was going to use a 15/16th mc from 91 civic ex should i get the brake booster from that car also?
you got me dude, just search around. I would say it has to be on that thread but I dunno. Goodluck
Kidnkorner
15
04-16-2010 10:23 PM
fryman
12-28-2009 02:46 AM
staticCRX
20
01-20-2005 01:50 PM
