installing tire valve stem, help quick!!
ok my buddy club rims did not come w/ any valve stems, so i went and picked some upa t pep boys. now i tried squeezing them in w/ hand, not happening!! ive never done this before so i have no idea. it seems you need some sort of tool. please inform me asap. thanks in advance
Re: installing tire valve stem, help quick!! (SleepnCiViC)
When you go to get tires installed on them they have a little tool that screws onto the stem and then it gets pulled through. It just takes a second with the tool. I don't know if I would try anything else. They don't usually charge to do this.
yes u need a tool if u watch a guy at a shop install them they have this tool that u screw the valve stem on to and pull it through.
Re: (SleepnCiViC)
Yeah you can buy a valve stem tool at like walmart I have one and I have put in lots of valve stems it is pretty easy. The tool is only a few bucks, and like everyone says all you have to do is put a light coat of dish soap on the rubber of the valve stem to act as lube and it will dry and then tread on the tool and pull it through till it snaps in to place and you should be done, and if you don't want to do it most shops will just pop them in for nothing before they mount your tires.
Just let the shop put them in when you get the tires on. I am assuming you don't have a tire mounter and balancer if you don't have a valve stem tool.
