Im throwing a CEL
Im throwing a CEL
Well I did a Intake mani swap on my ej6 from the y7 to a Z6 IM so im thorwing ethier a number 3 or 4? Like sometimes it only shows 3 and sometimes only shows 4? Im just trying to find out why. If its the cranks postion sensor where is that at?
Re: Im throwing a CEL (ARCHway Jtuned)
More then likely your throwing code 3 if you saw that. I doubt your throwing a 4 because you shouldnt have touched the dist. Code 3 is map sensor and just make sure you plugged it in correctly, and check if you might have switched it with the TPS. Also are you using your stock throttle body or the z6 TB?
Re: Im throwing a CEL (Luserkid)
I am using the ported y7 one. and the tps and map sensor ones are not switced i did that and it ran like *** so its not that.
JibOnALib
12
09-14-2005 11:51 AM
MIZIKETSK
01-15-2004 11:02 AM
