Im picking up full GSR suspension for my EG tomorrow, what all should be included ?
Just want to make sure I pickup everything I need for the full swap, dont want to end up missing something and leaving my car on jackstands for who knows how many days.
thanks guys.
thanks guys.
Re: Im picking up full GSR suspension for my EG tomorrow, what all should be included ? (n0se.)
you mostly have to be worried about the rear, make sure the rear includes the brake lines and ebrake cables or your going to have to buy new ones because the ones from your EG wont work unless its an Si in which case swapping the rear brakes would be worthless
Re: Im picking up full GSR suspension for my EG tomorrow, what all should be included ? (bretx0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bretx0r »</TD></TR><TR><TD CLASS="quote">you mostly have to be worried about the rear, make sure the rear includes the brake lines and ebrake cables or your going to have to buy new ones because the ones from your EG wont work unless its an Si in which case swapping the rear brakes would be worthless</TD></TR></TABLE>
thanks for the info, can anyone possibly list which parts in need exactly ?
1) both side complete trailing arm which include the rotor/caliper/brake line.
2) both side e-brake cable (make sure it the disc type not cable)
3) both front complete knuckle which included the rotor/caliper/brake line.
and these are optional but if it included then take it..the upper and lower control arm and the compensator arm (but these i recomend you using your old one that was for your car). i believe that should be all that is needed..btw..the master cyle\inder and booster if possible.
Re: Im picking up full GSR suspension for my EG tomorrow, what all should be included ? (C uR eX)
