Ign. Control Module Recommendation
Hello fellow honda-tech members. I have searched and found a lot of info about the ignition control module, but not My question is, can someone recommend a quality ICM that is not NEC or Hitachi, as they run $100+. My old original NEC had started to randomly die for a few seconds every once in a while so I bought an ICM off of Ebay and it worked for a while, now its making my tach bounce all over the place past 5k, but other than that it works ok.
thanks
Larry
thanks
Larry
Re: Ign. Control Module Recommendation
so NEC or Hitachi... thats what I figured... I was going to buy another different ICM, but that would be $30 that I should just go ahead and buy the right thing... done and on its way
thanks
Larry
thanks
Larry
Just a follow up to this.
It is best just to go ahead and buy the NEC ICM if you want everything to work right, and the tach to be stable.
right after this it started misfiring, turned out to be bad plug wires which I change d out with stock Honda parts, no aftermarket stuff this time
http://auroraignitionwires.com/conte...-us/d1225.html
