Bad Ignition Control Module?
Old 08-20-2001, 09:55 AM
keithv's Avatar
Default Bad Ignition Control Module?
My stock tach "floats" (it will oscillates about a 1k RPMs range) once I hit higher RPMs. I was screwing around with the tach to wire up my aftermarket tach and things seemed to work fine before, BUT we were breaking the motor in so we never climbed much above 6k RPMs.
Somone mentioned the Ignition Control module could be bad. What do you all think?
Thanks!
Old 08-20-2001, 01:10 PM
kahren's Avatar
Default Re: Bad Ignition Control Module? (breaka_1_9)
check if your distributor is bolted up good
celavi
05-11-2012 09:49 AM
si_motor_spt
08-16-2007 05:12 AM
b_serious
05-12-2006 10:21 AM
skunktuned
06-25-2004 03:50 PM
Quick Reply: Bad Ignition Control Module?
