Idle problems need help
Today i was installing a tachometer, aftermarket because my spedo is broke, so i am using friends cluster w/ no tach for a working spedo. as i was mounting the tachometer, my friend was dinkering around with my ecu. splicing wires away trying to figure out which one goes where.. i need to know if this could mess with my idle, i checked plugs already they are all good.. lemme know what cha got
Re: Idle problems need help (Mr_Moos)
I would say yes, not sure though. I guess post which what wires he messed with and let the experts tell you.
1 Post
yes,that could certainly lead to problems.what wires did he mess with?
do you have any trouble codes now?
BTW-you can swap his working speedo into your tach-equipped cluster so you have everything you need.
Chris
Chris
Re: Idle problems need help (TeamNextGenChris)
yah i believe i through up 2 long and 2 short, i will have to double check to see which wires he messed with..
ArchAngel Sabastian
09-11-2002 09:29 PM
