Idle problems! Help please! b18b in ek
Old 01-05-2008, 06:55 PM
pmpm06's Avatar
Default Idle problems! Help please! b18b in ek
here's my problem, pretty similar to everyone's that i've searched around on, but with a difference or two...
ok the car, a 96 civic dx with an obd I ls swap running a chipped p06. on cold start the car will idle from 1500-2000 rpm's really fast, up and down. as soon as the motor is fully warmed up the idle will smooth out, and idle low, usually 1000 rpm's or less. but here's where my real problem is, even after the motor warms up and the idle smooths out, if i'm cruising along in a gear at low rpm's, usually 2500 or less, the car will still act like it did when it idled irratic when cold. the rpms jump and fall really fast within 500 rpms and the car shakes awful like i'm just tapping the gas and letting off of it over and over until i give it more throttle and the rpm's build back up......anyone else had this problem? have any advice??
Old 01-05-2008, 08:18 PM
duefuss's Avatar
Default Re: Idle problems! Help please! b18b in ek (pmpm06)
you know its funny i have the same problem but i know what mine is i need my ecu tuned.... and i dont know if this helps but start it with your map sensor unplugged..... just a thought.... mine runs better with out it hooked up. dont ask me why mine does. when did all this start happening??
Old 01-05-2008, 09:00 PM
veriest1's Avatar
Hmm... sounds like a vacuum leak or leak in the intake piping to me. I've seen this fix such an issue on non-Honda vehicles.
Old 01-05-2008, 09:07 PM
duefuss's Avatar
yeah if it was ust a high idle... but its not its spuratic so its either tps needs adjusting or theres a sensor not working properly, or like in my case he needs a new base map on his ecu
Old 01-06-2008, 03:39 PM
pmpm06's Avatar
so what would be my best best to start with? ecu or tps??
Old 01-08-2008, 11:58 AM
pmpm06's Avatar
anyone else had this problem?? i don't know where to start?? i don't wanna buy an ecu not knowing if it's gonna fix this idle because other than that, it runs great on the chipped p06
Old 01-08-2008, 03:53 PM
duefuss's Avatar
Default Re: (pmpm06)
Well when did all this start? did it start after any mods or anything?
Old 01-08-2008, 03:56 PM
Ex-Eg-Driver's Avatar
get a buddy with a LS OBD1 ecu....try that...then work your way from there.
Old 01-08-2008, 04:01 PM
-JAWSHUA-'s Avatar
i'm having the same "symptoms" do you have a CEL?? at first i changed the primary O2 and the CEL went away and now its starting to get jerky again with the CEL. i need to see what code its throwing, i gotta be at j's gathering on sunday man.
Old 01-08-2008, 04:22 PM
duefuss's Avatar
Default Re: (CTRwannabe)
I finnally got my troubles fixed i adjusted my idle first then adjusted the tps off the new adjusted throtle position (the key was doing it with a volt meter and not a plug n play to read my sensor settings ). but yeah check your cel codes see whats up if youve done anything to the TB readjust your idle then adjust the tps off your new idle settings.
Old 01-09-2008, 11:02 PM
-JAWSHUA-'s Avatar
thanks alot man, imma have to try that.
Old 01-13-2008, 02:25 PM
duefuss's Avatar
well howd it work out?
dragonvoi
11
09-03-2011 01:31 PM
Eran
11
08-09-2006 11:33 PM
zurg
11-08-2004 08:29 AM
BeerBaron105
01-27-2004 01:14 PM
T-Mo
11
09-28-2003 10:17 AM
Quick Reply: Idle problems! Help please! b18b in ek
