ice/frost forming on inside of windshield??
I have a 92 cx and i woke up this morning to go to work and i got in my car and started it up to get it warm. i noticed a thin layer of frost/ice on the windshield. i was like ok i got time and i just let the defroster take care of it. it was taking a while so i went outside to scrape it off and then i noticed it wasnt even on the outside, it was on the inside. It was the same **** that usually forms on the outside only it was on the inside. anyone else ever have this problem. i have no clue as to why it happened. My doors were secure and the windows were all the way up. I checked that. Anyone offer a reason or a solution. Thanks
Re: ice/frost forming on inside of windshield?? (GsR HtCh)
Does the car have A/C?
Did you have it on full defrost? I believe the compressor runs on full defrost to help remove moisture. Could also cause a little ice to form, rom the cool air from the evaporator...
Get rid of the water in your carpet or floor mats. With lower temperatures over night and that added moisture in the car will cause condensation on your windows. If you find its next to impossible to remove all water from your interrior, try leaving one of your windows just slightly open(a few mm)it will permit the moisture to escape....Hope this helps
Modified by zero grip at 3:01 PM 12/7/2003
Re: ice/frost forming on inside of windshield?? (zero grip)
thats the thing. i dont have Carpet. No interior except dash and seats. and No ac at all. im confused.
interior is bone dry
make sure the drain holes are plugged up too. i know there is at least one in the spare tire wheel well. start from there, moisture has to be getting in from somewhere.
ill give it a look over. i mean there was nothing on the outside. nothing at all. makes no sense to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR HtCh »</TD></TR><TR><TD CLASS="quote">ill give it a look over. i mean there was nothing on the outside. nothing at all. makes no sense to me.</TD></TR></TABLE>
It happens to me also...pita....I have full interior...checked the carpet and nothing was wet.
H-T Poker champion
used to happen to me all the time because I had a huge crack in my windshield.. got the windshield replaced and it hasnt happened since. there is prolly a compromise in the integrity of your windshield somewhere.
Re: ice/frost forming on inside of windshield?? (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 »</TD></TR><TR><TD CLASS="quote">used to happen to me all the time because I had a huge crack in my windshield.. got the windshield replaced and it hasnt happened since. there is prolly a compromise in the integrity of your windshield somewhere. </TD></TR></TABLE>
AHHHHHH....my window creaks when I drive when its cold...maybe it is loose?
i HAS questions ?
Happened to my 91 Accord and a lot of my friends cars here all the time, new and old. My only suggestion would be to start the car up 5 minutes earlier and let it defrost.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR HtCh »</TD></TR><TR><TD CLASS="quote">some one say something</TD></TR></TABLE>
something...there are you happy
Re: ice/frost forming on inside of windshield?? (JDM-97CX)
hey i went out today and none was on the inside. it was all on the outside. im confused. i seriously think someone flipped my windshield around. oh well. Ill get over it.
HatchBox
01-15-2003 07:53 PM
