need help car dies when braking
Gsr swap in a 99 honda civic... so the car dies out when it comes to a complete stop... so im wondering what the problem can be?,...any help would be appreciated
Re: (Sparaker)
yes the enging check light is on for some water tempature sensor or sumthin like that...u think that has to do with the engine dying out while loosing rpms?
I had this problem once, and i cleaned the IACV (idle Air Control Valve), FITV (Fast Idle Thermo Valve), Throttle Body. And the car started running great again. You could possibly get those things cleaned first as a start. Next replace the pcv valve cause sometimes its the culprit for dropping rpms.
Re: FITV and Throttle (jojogalan)
i searched and found this..hopefully it will help u out https://honda-tech.com/zerothread?id=1844067
