i wanna cut my springs..
#51
Re: i wanna cut my springs..
Cmon....obviously he didn't think of it. 99.9% of this forum isn't Bill Nye the science guy. They just do stuff. To be fair, you don't really need to think about any of that crap. If the car rides well...who cares what the numbers actually are.
I'm an engineering student and I wouldn't even care about numbers that much. I'm also a person with common sense. If you're cutting springs...all you're thinking about is getting off the hook cheap.
What do you mean what is the spring constant nessecary to keep the car from bottoming while acclerating or decelerating? You think that this dude's car was on bumpstops when he floored his single cam? He said he kept about 1 finger gap. I'm sure it was fine. If he would have cut down his bumpstops, it would have just rode like a car with too low and too soft lowering springs. It would have bounced a little....big deal.
Also..the spring CONSTANT stays the same as it is the spring CONSTANT. That's just a measure of how many newtons it takes to compress a spring a certain amount...or how much energy is inside the spring. I doubt that the spring's rate changed by cutting it. If it was a 240lb/in spring before...it's still a 240lb spring now...it's just shorter. I guess since it was a progressive spring, the progressiveness would depend on which coils he cut out....
Too complicated. He's not building a F1 car.
FYI, the number of coils in a spring affects the spring constant. It's only CONSTANT if the dimensions of the spring remain CONSTANT.
#52
save up for decent suspension to be able to lower your car correctly..
i speak from experience that i went the "cheap" route.. pretty much the biggest mistake i made on my car and i ended up saving and buying better suspension anyway..
#56
lets just stay on subject,
obviously cut springs are
not good at all, even some-
times dangerous.. so just
wait to get some springs!!
Markb16a
10
09-11-2006 05:58 AM
